Wie können wir Ihnen helfen?
How to build a mining rig
30. April 2026 16:15
1. Let's choose the hardware
Look before you leap!
Motherboard
🗿 The Processor (CPU)
If you are NOT going to mine using a processor, its performance doesn't matter.
If the processor is NOT involved in mining, running the OS and background processes will be the only task. So even an old Intel Core Duo E8400 is enough.
🔌Mining rig's power supplying
Connections and adapters
RAM
You assembled all the parts of the rig and are ready to go. Slow down and take a look at your rig. Have you connected everything correctly? For example, an improperly inserted RAM bar can prevent the farm from starting and reduce the hashrate on the CPU while mining.
Cooling Fans
Processor’s Cooler
☝ A cooling fan is a good thing. A correctly installed cooling fan is even better!
Storage
Storage Types
  • Speed. Using an SSD, your farm will start up fast, and you won't waste time waiting for your operating system to boot up.
Make sure that your motherboard and processor support enough PCI-E lines. NVME connector often combined with a PCI-E connector — you'll have to choose one or the other. A graphics card and the NVME storage may not work simultaneously.
Risers
Riser Types
The more GPUs — the better! But how to connect them if you don't have enough PCI-E x16 slots? Using a riser, of course.
🩺Diagnostics
    Motherboard with a POST Code Indicator
🎛 BIOS Setup
Usually, configuring the BIOS is not difficult when your computer has a minimum of components. But when you connect several video cards, you start dancing with tambourines:
  1. Update your motherboard’s BIOS — outdated BIOS may hide important settings.
  2. Enable Above 4G Decoding.
  6. Disable CSM mode.
Paging file
**We will tell you how to do it and how much to set it.**
Power settings
On the selected power profile, click "Power Scheme Settings” Next, click on "Change Advanced Settings”
Find "Hard Disk" → "Turn off hard disk after" → set to "0" — “Never”
Prohibit USB Ports suspension
3. Install Kryptex!
4. Helpful hints
  • **Don't overclock the cards as much as possible.** Watch the stability of the mining rig for at least 24 hours, only then step by step overclock your video cards.
Just kidding! 😅
If you don't want to or can't mine on Windows with our super handy software for some reason, we've given you the option to mine the way you like!
Any questions left?
Dieser Artikel ist in mehreren Sprachen verfügbar.
Registrieren
