How can we help?
June 2, 2026, 1:50 p.m.
  1. Speed:
  2. Fees:
  3. Scalability:
An invoice looks like this:
  1. Select "Deposit" → "BTC".
    • Take the network fee into account when withdrawing — it's 2% of the amount. To receive 0.0001 BTC, you need at least 0.000102 BTC in your balance: the payout amount plus a 0.000002 BTC fee.
Invoice Entry Error
  4. Network Fee Consideration — the network fee is 2% of the amount. To receive 0.0001 BTC, you need at least 0.000102 BTC in your balance: the payout amount plus a 0.000002 BTC fee.
Register
