Қалай көмектесе аламыз?
Mining settings
Мамыр 7, 2026, 11:05 Т.Ж.
    Kryptex Settings
    Misc -> Show miner windows
kryptex_nbminer.exe — NBMiner
Miner and its version
Found what you need? Then, try to put the new settings in Kryptex!
  1. Open the Kryptex settings.
    Miner's settings
Тіркелу
