เราจะช่วยคุณได้อย่างไร?
How do you choose a VPN for mining?
30 เมษายน 2026, 14:38
A VPN is necessary to bypass geographical restrictions and internet censorship. If you're having trouble accessing websites or services or suspect your internet provider is throttling your speed, a VPN can solve these problems.
VPNs are especially valuable for miners because they ensure connection stability and security. With a VPN, you can improve the quality of your connection and protect your data from prying eyes.
Here are some tips on what to look for when choosing a VPN.
🛡Security First
Your VPN should guarantee data protection and a strict no-logs policy. No one, not your provider, can see what you're doing online. Ensure the service you choose uses reliable encryption protocols like OpenVPN or WireGuard.
Pricing and Plans
Compare different subscription plans and evaluate their value. Some VPNs offer discounts on long-term subscriptions, which can save you money. Also, look for a free trial or a money-back guarantee.
Speed and Ping
For mining, connection stability, and low ping are crucial. The lower the latency, the better! Ideally, your VPN should offer a wide selection of low-load servers, allowing you to find optimal connections and avoid congested nodes.
You can check your internet speed or ping using Speedtest or 2ip.
Protocol Support
Check which protocols your VPN supports. IKEv2 and OpenVPN are excellent options, providing a good balance between security and speed. IKEv2 might be your best bet if you're using mobile devices due to its stability and quick connection recovery.
Leak Protection
Your VPN must have IP and DNS leak protection to prevent your real identity from being exposed online. It's also beneficial if the VPN has a Kill Switch feature, which automatically disconnects you if the VPN connection drops.
Compatibility
Before choosing a VPN, check its compatibility with your devices and operating systems. Some VPNs also offer the option to install on routers, which can be convenient if you have multiple devices on your network.
Additional Features
Remember extra features that can enhance your VPN experience. For example, Split Tunneling allows you to route some of your traffic through the VPN and some directly through your regular internet connection, which can boost performance.
A Quick Word on Protocols
Among the popular protocols are IKEv2, Shadowsocks, OpenVPN, and Lightway. IKEv2 offers high speed and stability, especially on mobile devices, while Shadowsocks is excellent for bypassing internet censorship but isn't a complete VPN. OpenVPN remains the gold standard, providing exceptional security and flexibility. Lightway, developed by ExpressVPN, offers high speed and efficiency but has limited support.
💥Helpful Articles:
ลงทะเบียน
