How to start mining on Kryptex pools
16/12/2022
Step one — create a wallet for your crypto.
For each coin, you can use any wallet format suitable: physical, local, mobile wallet, or generate an address on an stock exchange.
You can trade your crypto on online exchangers: Binance, Gate.io, MEXC, CoinEx, ByBit
- For BTC, we recommend Trust Wallet, Bitcoin Core
- For ETHW, we recommend Metamask.io (Check the detailed instruction)
- For ETC, we recommend Trust Wallet, Coinomi
- For RVN, we recommend Trust Wallet, Coinomi
- For ERGO, we recommend mobile apps Ergo Wallet (Android) or Terminus Wallet (iOS). (Check the detailed instruction)
- For KASPA, we recommend KASPA Online Wallet (Check the detailed instruction)
- For NEXA, we recommend Otoplo or Nexa wallets (Check the detailed instruction)
- For XMR, we recommend Cake Wallet or Feather Wallet. You can find alternative wallets at the developer’s website.
- For IRON, we recommend Node App Wallet or FoxWallet. (Check the detailed instruction)
- For CFX, we recommend Fluent Wallet. (Check the detailed instruction)
- For ZEPH, we recommend Zephyr Wallet. (Check the detailed instruction)
- For KLS, we recommend Karlsen Online Wallet. (Check the detailed instruction)
- For PYI, we recommend Pyrin Online Wallet. (Check the detailed instruction)
- For XNA, we recommend Rebel Wallet. (Check the detailed instruction)
- For CLORE, we recommend Vidulum Wallet. (Check the detailed instruction)
- For ALPH, we recommend Extension Wallet. (Check the detailed instruction)
- For NIR, we recommend Nirmata GUI. (Check the detailed instruction)
- For SDR, we recommend Sedra Online Wallet. (Check the detailed instruction)
It is easy to create a сrypto wallet — check our article.
We do not recommend mining on exchange. If you choose mining on an exchange, you do so at your own risk. Not your keys - not your crypto!
Step two — choose the mining pool.
Connect the pool — pool.kryptex.com
Coin | Pool address | Wallet format | Password |
BTC | btc.kryptex.network:7777 |
WALLET_ADDRESS.WORKER_NAME |
x or leave blank |
ETC | etc.kryptex.network:7777 |
x or leave blank |
ETHW | ethw.kryptex.network:7777 |
x or leave blank |
RVN | rvn.kryptex.network:7777 |
x or leave blank |
KASPA | kas.kryptex.network:7777 |
x or leave blank |
NEXA | nexa.kryptex.network:7777 |
x or leave blank |
CFX | cfx.kryptex.network:7777 |
x or leave blank |
IRON | iron.kryptex.network:7777 |
x or leave blank |
ERGO | erg.kryptex.network:7777 |
x or leave blank |
XMR | xmr.kryptex.network:7777 |
x or leave blank |
ZEPH | zeph.kryptex.network:7777 |
x or leave blank |
KLS | kls.kryptex.network:7777 |
x or leave blank |
PYI | pyi.kryptex.network:7777 |
x or leave blank |
XNA | xna.kryptex.network:7777 |
x or leave blank |
CLORE | clore.kryptex.network:7777 |
x or leave blank |
ALPH | alph.kryptex.network:7777 |
x or leave blank |
NIR | nir.kryptex.network:7777 |
x or leave blank |
SDR | sdr.kryptex.network:7777 |
x or leave blank |
- Choose the mining pool you are going to mine.
- Enter your wallet address into the “Wallet Address” cell.
WALLET_ADDRESS
— use your own wallet address, from a previously registered wallet.
Example:0x5A799e14b2024039EAfAA498d6299fe47FcfE6Df
- Enter your mining rig’s name to the “Worker Name” cell.
WORKER_NAME
— Rig name must be no more than 32 characters, written in the Latin alphabet and without spaces. May contain digits0-9
, signs-
and_
. For example,MyRig1
. - Create an empty
.bat
file and copy-paste the launching command for your miner from the cell “BAT file example”.
Step three — choose the mining method.
- Connect with HiveOS;
- Connect with RaveOS;
- Connect with BAT file (Windows);
Our pools are ASIC compatible!
Use these settings to connect ASICs:
BTC | stratum+tcp://btc.kryptex.network:7777 |
x or leave blank |
ETC | stratum+tcp://etc.kryptex.network:7777 |
x or leave blank |
ETHW | stratum+tcp://ethw.kryptex.network:7777 |
x or leave blank |
XMR | stratum+tcp://xmr.kryptex.network:7777 |
x or leave blank |
KASPA | stratum+tcp://kas.kryptex.network:7777 |
x or leave blank |
KLS | stratum+tcp://kls.kryptex.network:7777 |
x or leave blank |
SDR | stratum+tcp://sdr.kryptex.network:7777 |
x or leave blank |
WALLET_ADDRESS
— wallet address you use your own, from a previously registered wallet.
WORKER_NAME
— the name of Asic must be no more than 32 characters, written in Latin letters and with no spaces. It may contain the numbers 0-9
, as well as the characters -
and _
. For example, ASIC_1
Step four — Payouts!
Payouts processing hourly once reaching the payout threshold.
Press the “Settings” button.
Set the desired “Payment Threshold”. Minimum and maximum payment threshold mentioned at the pool home page. There is no payout fee — Kryptex pays it for you 🖤
In the "Ip Address" cell, enter the IP address of the worker whose name the site prompts you. The IP address must end the same as indicated in the prompt on the site (see the last digits). Learn your IP here https://ipinfo.io/ip
Press the “Submit” button.
