เราจะช่วยคุณได้อย่างไร?
4 มิถุนายน 2026, 18:46
  • in Ethereum ETH;
  • in Litecoin LTC;
  • in USDT (BEP20, TRC20);
  • in USDC (Solana);
  • BNB (Smart Chain);
  • TRX (Tron);
  • Volet.com payouts;
  • Bitrefill payouts;
  • PayPal US.
Available connection options:
  • krxXXXXXX
  • krxXXXXXX/Worker1
  • krxXXXXXX.Worker
  • krxxxxxxx.Worker
  • KRXXXXXXX.Worker
How to connect?
Alternatively, you can use your email as the wallet address. However, not all miners support this format. If you choose to use your email, include the worker name by adding a slash. Example: miner@gmail.com/worker.
BTC+FB btc.kryptex.network:7014 mining_username.worker_name x or nothing
FB fb.kryptex.network:7013 mining_username.worker_name x or nothing
BCH bch.kryptex.network:7015 mining_username.worker_name x or nothing
XEC xec.kryptex.network:7036 mining_username.worker_name x or nothing
DGB dgb.kryptex.network:7037 mining_username.worker_name x or nothing
LTC+DOGE+BEL+PEP ltc.kryptex.network:7016 mining_username.worker_name x or nothing
ALPH alph.kryptex.network:7010 mining_username.worker_name x or nothing
KAS kas.kryptex.network:7011 mining_username.worker_name x or nothing
RXD rxd.kryptex.network:7012 mining_username.worker_name x or nothing
ETC etc.kryptex.network:7033 mining_username.worker_name x or nothing
ETHW ethw.kryptex.network:7034 mining_username.worker_name x or nothing
OCTA octa.kryptex.network:7032 mining_username.worker_name x or nothing
XTM-SHA3X xtm-sha3x.kryptex.network:7039 mining_username.worker_name x or nothing
XMR xmr.kryptex.network:7029 mining_username.worker_name x or nothing
SAL sal.kryptex.network:7028 mining_username.worker_name x or nothing
XTM-RX xtm-rx.kryptex.network:7038 mining_username.worker_name x or nothing
ZEPH zeph.kryptex.network:7030 mining_username.worker_name x or nothing
CFX cfx.kryptex.network:7027 mining_username.worker_name x or nothing
XTM-C29 xtm-rx.kryptex.network:7040 mining_username.worker_name x or nothing
XEL xel.kryptex.network:7019 mining_username.worker_name x or nothing
IRON FISH iron.kryptex.network:7017 mining_username.worker_name x or nothing
RVN rvn.kryptex.network:7031 mining_username.worker_name x or nothing
PRL prl.kryptex.network:7048 mining_username.worker_name x or nothing
XNA xna.kryptex.network:7024 mining_username.worker_name x or nothing
ERGO erg.kryptex.network:7021 mining_username.worker_name x or nothing
NEXA nexa.kryptex.network:7026 mining_username.worker_name x or nothing
Connect on Windows
Connect on HiveOS
Creating the Wallet
  4. Confirm the wallet setup.
Create the Flight Sheet
Connect on RaveOS
Creating the Wallet
Connection Settings
  1. Choose the coin type.
  7. Save your configs.
  3. Next, follow these steps:
    • Select the appropriate wallet from the “Wallet” drop-down list.
Connect on ASIC/FPGA
❗Important Information
  3. Not all coins can be mined and exchanged for bitcoins. Check the table to see which coins are available for automatic exchange.
ลงทะเบียน
