How to start mining on Kryptex pools
16/12/2022
Step one — create a wallet for your crypto.
For each coin, you can use any wallet format suitable: physical, local, mobile wallet, or generate an address on an stock exchange.
You can trade your crypto on online exchangers: Binance, Gate.io, MEXC, CoinEx, ByBit
It is easy to create a сrypto wallet — check our article.
We do not recommend mining on exchange. If you choose mining on an exchange, you do so at your own risk. Not your keys - not your crypto!
Step two — choose the mining pool.
Connect the pool — pool.kryptex.com
BTC btc.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
ETC etc.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
ETHW ethw.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
RVN rvn.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
KASPA kas.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
NEXA nexa.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
CFX cfx.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
IRON iron.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
ERGO erg.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
XMR xmr.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
ZEPH zeph.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
KLS kls.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
PYI pyi.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
XNA xna.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
CLORE clore.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
ALPH alph.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
NIR nir.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
SDR sdr.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
  1. Choose the mining pool you are going to mine.
  2. Enter your wallet address into the “Wallet Address” cell.
    WALLET_ADDRESS — use your own wallet address, from a previously registered wallet.
    Example: 0x5A799e14b2024039EAfAA498d6299fe47FcfE6Df
  3. Enter your mining rig’s name to the “Worker Name” cell.
    WORKER_NAME — Rig name must be no more than 32 characters, written in the Latin alphabet and without spaces. May contain digits 0-9, signs -and _. For example, MyRig1.
  4. Create an empty .bat file and copy-paste the launching command for your miner from the cell “BAT file example”.
Step three — choose the mining method.
  1. Connect with HiveOS;
  2. Connect with RaveOS;
  3. Connect with BAT file (Windows);
Our pools are ASIC compatible!
Use these settings to connect ASICs:
BTC stratum+tcp://btc.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
ETC stratum+tcp://etc.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
ETHW stratum+tcp://ethw.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
XMR stratum+tcp://xmr.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
KASPA stratum+tcp://kas.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
KLS stratum+tcp://kls.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
SDR stratum+tcp://sdr.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
WALLET_ADDRESS — wallet address you use your own, from a previously registered wallet.
WORKER_NAME — the name of Asic must be no more than 32 characters, written in Latin letters and with no spaces. It may contain the numbers 0-9, as well as the characters - and _. For example, ASIC_1
Step four — Payouts!
Payouts processing hourly once reaching the payout threshold.
  4. In the "Ip Address" cell, enter the IP address of the worker whose name the site prompts you. The IP address must end the same as indicated in the prompt on the site (see the last digits). Learn your IP here https://ipinfo.io/ip
  5. Press the “Submit” button.
